vcPropertyContainer
A container of vcProperty objects.
Referenced by: vcAction.Properties, vcAssemblyPattern.Properties, vcAssemblyPatternSlot.Properties, vcAssemblyStep.ProcessParameters, ... (see more)
vcAction.Properties
vcAssemblyStep.Properties
vcBaseFrame.Properties
vcBehavior.Properties
vcCommand.Properties
vcComponent.Properties
vcConditionalScope.Properties
vcDof.Properties
vcFeature.Properties
vcFlowStepProcessConfiguration.Properties
vcJointDriver.Properties
vcKinSolver.PassiveValueProperties
vcKinSolver.Properties
vcLayoutItem.Properties
vcLayoutSchemaPropertyList.SchemaProperties
vcLinkJoint.Properties
vcNode.Properties
vcPositionFrame.Properties
vcPositionTarget.Properties
vcProcessFlowGroup.Properties
vcProcessFlowStep.Properties
vcProduct.Properties
vcProductCreatorBatchMode.Properties
vcProductCreatorDistributionMode.Properties
vcProductCreatorFeedBatch.Properties
vcProductCreatorSingleMode.Properties
vcProductCreatorTableMode.Properties
vcProductFilter.Properties
vcProductType.ComponentProperties
vcProductType.ProductProperties
vcProductType.Properties
vcProductTypeAssemblyPatternItem.Properties
vcProgram.Properties
vcPythonProcessHandler.Properties
vcRobotConfiguration.Properties
vcRobotProgram.Variables
vcRobotRoutine.Variables
vcRoutine.Properties
vcRrsRobotController.Properties
vcSequenceProcessConfiguration.Properties
vcSimInterfaceField.Properties
vcStatement.Properties
vcTransportLink.Properties
| AllowedReferenceValueTypes | list[String] | R | Gets the list of value types allowed in reference properties in this property container. |
| clear | None | None | Deletes all the user-created properties.See moreExceptions: ValueError: When there is no license to modify this property container. |
| create | vcProperty | vcPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new property of a given type and name to the property container.See moreParameters: type (vcPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given property name is empty or not unique. TypeError: When the creation of the given property type is not supported. Returns: vcProperty: The newly created property. |
| create | vcProperty | vcStepPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new step property of a given type and name to the property container.See moreParameters: type (vcStepPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given name is empty. ValueError: When this property container already has a property with same name. Returns: vcStepProperty: The newly created step property. |
| create | vcProperty | vcEnumPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new enum property of a given type and name to the property container.See moreParameters: type (vcEnumPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When given name is empty. ValueError: When this property container already has a property with same name. Returns: vcEnumPropertyType: The newly created enum property. |
| create | vcProperty | vcListPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new list property of a given type and name to the property container.See moreParameters: type (vcListPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given name is empty. ValueError: When this property container already has a property with same name. Returns: vcListProperty: The newly created list property. |
| create | vcProperty | vcLimitPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new limit property of a given type and name to the property container.See moreParameters: type (vcLimitPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given name is empty. ValueError: When this property container already has a property with same name. Returns: vcLimitProperty: The newly created limit property. |
| create | vcProperty | vcExpressionPropertyType type, String name, Optional Keyword[useExisting = Boolean] | Adds a new expression property of a given type and name to the property container.See moreParameters: type (vcExpressionPropertyType): Type for the created property. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given name is empty. ValueError: When this property container already has a property with same name. Returns: vcExpressionProperty: The newly created expression property. |
| create | vcProperty | vcReferencePropertyType type, String valueType, String name, Optional Keyword[useExisting = Boolean] | Adds a new reference property of a given type and name to the property container.See moreParameters: type (vcReferencePropertyType): Type for the created property. valueType (String): Type for the reference property value(s). The value must be included in vcPropertyContainer.AllowedReferenceValues. name (String): Name for the created property. useExisting (Boolean): Should an existing property with the same type and name be returned instead of erroring. Defaults to True. Exceptions: ValueError: When there is no license to modify this property container. ValueError: When given name is empty. ValueError: When this property container already has a property with same name. ValueError: When given valueType is not in the list of allowed reference value types of this property container. Returns: vcReferenceProperty: The newly created property. |
| OnChanged | vcPropertyContainer container, vcProperty property, vcMoveType moveType | Triggered when content of the property container changes.See moreParameters: container (vcPropertyContainer): The container that changed. property (vcProperty): The property that changed. moveType (vcMoveType): The operation type. |
